1 - 19 of 19 Posts
Hello, everybody... Got this tire from a friend of a friend and looking to see if anyone can tell from the markings - how old it is, whose car it may have been on, etc.
Thanks!
I am assuming g it may be from a car no. 10. Curious if anyone knows who or how old it may be. The markings must mean something. Thanks!
CraZyGordoManiac
Well from what I've found, the GOODYEAR #1 tires were used from '93(when they also switched to yellow lettering) to '04. More than likely it's a tire from the late 90's, early '00s. Probably what you have is a Johnny Benson tire.
Reactions: ffgo24
Larson Collector
Obviously the LR means Left Rear.... Although the 10 could be the car number, it could also be a code the team used for tire pressure.... Lets remember most of the Wheels have the car numbers stamped on them already... I wonder whats up with the highlighted 2 the most.... Sure seems like a lot of wasted time for a crew member on a race weekend
Reactions: ffgo24
Cool! Thanks for the info! Didn't know if the codes stamped on the tire meant anything. Like the d6352 for example.
Discussion Starter · #8 ·
good point on the "10". Didn't think of that. Yes, the highlighting of the 2 was quite curious as well. Maybe a bored crew member during a rain delay :)
Larson Collector
If it made it to the track it was only scuffed, quite a few nipples on it yet too. as well as all the markings being very fresh.
Reactions: ffgo24
The "10" is what set of tires it's from, so this tire was a left rear from the 10th set.. The# stamped into the rubber starting with the letter D is the compound makeup of the tire... They use different compounds on the left side & right side of the car & also different compounds at different tracks..
Living the racing life.
The date code on the tire looks like it's from March of 2002...
Reactions: ffgo24
CraZyGordoManiac
Here's a weird little tidbit: I might have been able to connect the tire to what team it's from simply by that outlined #2 on it. I was looking up cars from 2003 when a JPM car from '07 popped in Google search. Note the numbers on the tires lol I would suffice to say that the tire might be from Ganassi '02.
Nice work on finding the info on the tire.
To add to what I said earlier about how the DXXX# tells what the tire compound is....... It may also tell what batch they're from. Teams try to match up the #'s when putting a set together to get what they call a "good set" of tires...
The highlighted or outlined # I believe is done by the guys from Goodyear who mount the tires to the teams rims....I'm not sure about that though, so I'm going to use a lifeline & phone a friend....lol. I'll report back tomorrow.... :)
The 06/02 date code indicates the tire was built in the 6th week of 2002. At that time, Benson was the driver. Chances are you have the LR off Johnnys #10
Discussion Starter · #17 ·
Wow! Just wow. You guys here rock. Can't believe the amount of info, @Nascar24 the odds of finding that pic with the outlined 2... Unreal! Thanks everyone!
Talked to a friend today who knows everything there is to know about NASCAR tires & the meaning of all those marks.... He asked me to forward your tire pics to his email & said when he gets a chance he'll take a look & let me know more, so stay tuned........
@ffgo24.... Can you take a clear pic of the all black area between the word Eagle & Goodyear....In that area there should be some crayon markings that might be faded out that will tell you what team it came from...Example LS31, which would mean left side 31 team....RS 31 would obviously be right side 31 team. ..also if you could send a pic of the bar code # ? That will help my guy to identify which race it may have come from....
1 - 19 of 19 Posts
