1 - 20 of 23 Posts
Camaro Crazy
Looking at ADC Diecast one thing that keeps getting to me is how inaccurate the nose on these is modelled.
Going from there, I do not particularly like the exhaust either. In the end there are plenty of areas in the diecast that I do not like.... but I really like those Dirt Late Model race cars.
The solution of course is, if you don't like what others do, do it yourself.
I found some plans on a 2008 Rocket Chassis (68 pages) and decided to give this a try. Scratch building.
I do accept that this will be a bit more tricky then hunting down a diecast on ebay, buying it, getting it to Europe and taking it out of the box. So I do very much hope this will all be worth it and I will end up with a kickass Dirt model within now and 25 years ;)
Here are the very beginnings of the project. Plenty of thin brass tubing for the main chassis. I still need to source thinner tubes for all the tubing and supports though, but I can start cutting and bending with this.
I also bought supplies to solder all the joints. Soldering is far more valid then welding forthe one reason that a soldering iron fits on the kitchen table and a TIG welding machine including gas doesn't.
I also bought some thin sheet metal for the driver compartment and the bodywork.
Camaro Crazy
Discussion Starter · #2 ·
Got a start on the frame, most of an engine, a seat and a steering wheek. Stilll have to fab some headers that will fit in the rocket chassis
Camaro Crazy
Even though it's been really slow going in the past few weeks, things are coming along
A few weeks ago I already took hold of the paints I will need to eventually paint the car, as well as another scale model buidling project I will outsource. Today I received a big box of laser etched parts for the late model build
This thing looks a lot better with a nose cone. And this nose looks a lot better then anything ADC ever produced. I ordered 2 ;)
Miscellanious suspension and chassis parts
Rod ends, birdcages and jacob ladder
Disc brake rotors, wheel hubs and wheel covers/beadlocks
All of this set me back quite a few bucks.
they look great do they cost a lot
Camaro Crazy
I paid about $70 for the photo etched parts
Furthermore some $30 in paint
$5 for the wire used to build the chassis
$10 for soldering supplies
$15 for sheetmetal to build the body
So now I only need wheels, springs, stuff to build shocks and some othe miscellanious parts as well as decals. Looking at just under in material cost $200 for this one
awesome.ihave about 40 custom nascars in 1/64 and somewere hard to make. i admire your guts in trying this. cant wait for the end results.
Camaro Crazy
Discussion Starter · #8 · (Edited)
Thank you Wayne
2 months ago my girlfriend and I were blessed with a baby girl, and I must admit that with that change my time to persue hobbies like these is somewhat limited. I am still determined to do this, and to do it right. I will try to post regular updates here, even though I expect the final result will still be months away
For now, visual eye candy. Here is a custom I did a while ago
DSC_3658 by b j, on Flickr
Closeted Logano Fan
Really anticipating to see how it'll turn out.
From what I've seen, you have the hardest part outta the way. Now it's just hanging the other parts. You already know what you are doing. AND you have the passion, I believe you have this handled! Keep us posted and best of luck!
Reactions: the solitaire
Ridiculous talent on display here....great work buddy!
Camaro Crazy
Discussion Starter · #12 ·
So, as I mentioned in my initial post, one of the reasons I started this is the ADC nose
Here is the real deal
Now below you see, on the left, an ADC model, and on the right, the nose cone Michael Crowley at dirtmodeler.com crafted. These are available at his online store and only require careful cutting and sanding to shape. I might even still cut a small ridge off, but I think I'm pretty close
Different view
I now also have a full containment seat, drive shaft, instruments and fire extinguisher for this build, scrounged from a NASCAR diecast
Camaro Crazy
Discussion Starter · #13 ·
Today the first photo etched frame parts were fitted. These are some vital reference parts. In a real car, all measurements start at the rear axle, but in this build I have to go work backwards because there are some parts with fixed sizes that will need to fit.
So I fit the front crossmember and radiator mounts in there. Next up will be the engine mounts
Camaro Crazy
Discussion Starter · #14 ·
The photo etched parts and the printed plans do not align 100%. As a result I generated a bit of tension into the frame, one joint cracked and the frame warped. I now have to undo 2 further joints, move them 1/32" and solder them up again.
Just a minor setback as I was able to trace the tensioned areas back to these two joints and the one that gave in. Should be back on track soon to start work on the motor mounts.
I also found two further shops.
One sells resin wheels and tires with any thinkeable profile, size and offset, and one that sells miniaturized nuts, bolts and steel braided wire among other things.
Cost of this project will go through the roof!
IF you are gonna build many of these, maybe you should build a "jig", that would save this from occurring again, AND also save time building cars again in the future.
Camaro Crazy
Discussion Starter · #16 ·
Ken, if I do decide tomake more of these I most certainly will buidla whole set of jigs to helpme in the various stages of building this chassis. Doing it all "freehand" is quite a pain.
As for now, I'm trying to get hold of a naked ADC chassis to see how a sheetmetal build on one of them looks. Wouldn't solve the header issue, but I might as well pull the headers and add some detail on the ADC chassis while I'm at it. Might be a solution that is $150 cheaper then building from scratch, and it's a hell of a lot faster too!
Still, this is a challenge I want to finish now that I started it, and I want to make it as good as I possibly can, even if I end up eating dry bread and drinking tap water by the end of the month because the money wasspent on parts for this build :)
Reactions: FFighter_21
I admire your dedication.......
Camaro Crazy
Discussion Starter · #18 ·
Not much news here. I ordered a set of decals from Pattos, but I'm also trying to contact a driver to get an approval for replicating a 2nd car. I found that with a little pushing and shoving I can actually make space for 2 late models :)
Team Caliber. "Anything less is just a Toy"
WOW! this is simply outstanding!
I wish I had the skills to do something like this.
..can't wait to see another update!!
:cool::cool::cool:
Camaro Crazy
Discussion Starter · #20 ·
Not much of an update, but the chassis is straight again, and I added the motormounts, some additional support tubing and started building the driver cell reinforcements
1 - 20 of 23 Posts
